  • Страница 2 из 5
Форум радиолюбителей » СХЕМЫ » МЕТАЛЛОИСКАТЕЛИ » Металлоискатель Шанс - 03HP (Обсуждаем сборку и наладку прибора)
Сб, 12.08.2017, 07:15 | Сообщение # 11
Boltyara
  Постов: 2777  Offline Друзья
ahmdi, Author's documentation
Сб, 12.08.2017, 07:15 | Сообщение # 12
ahmdi
  Постов: 8  Offline ОК
thank you all
I have a question.
how is the dept of this metal detector for a 20*20 metal?
can work man just with a loop? if yes how?
Сб, 12.08.2017, 07:15 | Сообщение # 13
Boltyara
Сб, 12.08.2017, 07:15 | Сообщение # 14
ahmdi
thank you boltyara
this metal detector has 2 coils, a sender ans a reciever, is there any way to use just a coil?
Сб, 12.08.2017, 07:16 | Сообщение # 15
Boltyara
ahmdi, детектор работает с двумя катушками. Две катушки можно вставить в один корпус. The detector works with two coils. Two coils can be inserted in one box.
Сб, 12.08.2017, 07:16 | Сообщение # 16
ahmdi
than you boltyara hands
please see this picture and say. is that correct, when man puts sender coil and sender coil together?
Сб, 12.08.2017, 07:16 | Сообщение # 17
Andre-TT
  Постов: 78  Offline ОК
Yes, that's right
Сб, 12.08.2017, 07:16 | Сообщение # 18
ahmdi
thank you Andre-TT
i want to build a 60*60 coil, how must be diameter and number of wire?
Сб, 12.08.2017, 07:16 | Сообщение # 19
Andre-TT
Coil 1mx1m has 16 turns wires of 1.5mm square for TX and 16 wires of 0.29mm square for RX.
Coil 60x60 has 20 turns.
It's all written in post №307
Сб, 12.08.2017, 07:16 | Сообщение # 20
Kuzmi4
  Постов: 88  Offline ОК
ahmdi, I also did the CHANCE-03 scheme with the changes. Changed the circuit and looked for another design of the coils. The information is posted on the forum. Please answer, what changes did you make in the scheme? And why?
  • Страница 2 из 5
